Browse Forums Landscape & Garden Design 1 Nov 06, 2011 5:56 pm Hello. So happy to have a place to ask people questions! How far can you run a reticulation system from your tap with out having to resort to solanoids? My back yard is quite big and I want to run retic along the 3 fence lines and along the patio. I know water pressure has something to do with this as well but am a bit bomboarded after picking up lots of leaflets from Bunnings. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ P1010448 by hels40, on Flickr Thanks Reticulation system question 2Nov 08, 2011 10:02 pm Not very. Running retic off taps is not going to end well for significant areas. Don't be scared of installing valves etc. it's easy. Retic off a tap is sometimes a suitable compromise in small court yards. Reticulation system question 3Nov 08, 2011 10:04 pm Make sure your advice comes from a trained irrigation specialist. The difference will ensure money well spent and a landscape that works at improving the value of your property. I'll post some links later Reticulation system question 4Nov 08, 2011 10:06 pm More importantly will be the way water is delivered is going to be the most efficient possible. There is some rubbish systems and confusing info out there. Do a search here. I've posted a fair bit on this question. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19515 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9792 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13484 |
