Browse Forums Landscape & Garden Design 1 Oct 30, 2011 10:01 pm Was helping my folks to build a pergola, we dug holes about 60cm deep, placed piece of brick at the bottom then planted the timber posts in and poured quickset concrete mix to about 15cm from the top. Some visiting relative was saying we should have concreted all the way to the top or the base of the posts will rot over time because they are buried unprotected. Is that true? I thought concrete was used for structural purpose only? Should we pour more concrete? Re: Treated timber post + quickset concrete mix 2Oct 31, 2011 7:51 am Ideally you don't want the timber to go anywhere near the ground. There is special stilts for timber that dynabolt into the concrete. Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: Treated timber post + quickset concrete mix 4Oct 31, 2011 8:24 pm You can get a variety of different stirrups (usually galvanised) that you set into the concrete and then bolt the post to the stirrup. It stops the post from coming into contact with ground. That's how we did our pergola and it fairly standard practice afaik to use stirrups. there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18382 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16105 Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1663 |
