Browse Forums Landscape & Garden Design 1 Oct 23, 2011 9:47 am Can anyone suggest a nice evergreen tree for the backyard that should grow to a height of around 8 metres to maintain privacy? Also we already have both sides of the house with a brick fence that extends only partly into the backyard on both sides. The rest of the backyard we need to replace the fence and was considering continuing with the brick wall to make it look consistent. Is this a bad idea with the planting of a tree as I am worried that roots could damage and crack the wall later. How far would the tree need to be from the wall for this to not be an issue. Or should I just use a Colorbond fencing instead? Re: Help with tree selection for backyard 2Oct 23, 2011 9:07 pm Hi, I have found some great tree suggestions on here, put a key word search in the forums and you'll find a heap. Also this is a useful link. http://www.flemings.com.au/topten_intro.asp Good luck, there are so many options! Re: Help with tree selection for backyard 4Oct 24, 2011 10:46 am bdd Can anyone suggest a nice evergreen tree for the backyard that should grow to a height of around 8 metres to maintain privacy? Also we already have both sides of the house with a brick fence that extends only partly into the backyard on both sides. The rest of the backyard we need to replace the fence and was considering continuing with the brick wall to make it look consistent. Is this a bad idea with the planting of a tree as I am worried that roots could damage and crack the wall later. How far would the tree need to be from the wall for this to not be an issue. Or should I just use a Colorbond fencing instead? Where do you live? Roots travel far and wide, the most destructive roots are within the first 2-3 metres of the trunk, eg the roots that lift paving etc. Further out the roots are far finer and the damage they usually cause has do with moisture levels in the soil, i.e. the tree roots suck an area dry and the foundations move causing a wall to crack. A rough estimate for a 8m high tree would be an 8m spread of roots from the trunk. The roots will go a lot further out than that but they are unlikely to cause any problems. Hi there, we have classic cream gutters, fascia’s, roller door and undercover carport. We are are going to paint the roof a terracotta orange colour. After some… 0 4602 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16717 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9019 |
