Browse Forums Landscape & Garden Design 1 Oct 19, 2011 3:12 pm I have a grey water system connected to the bioline irrigation system (these are the low pressure lines, not pressure-compensating ones). I laid it all out properly with a 25mm feeder line and then various pieces of 2-3 metres bioline along the feeder line. I found that it was not releasing fast enough, so I extended the line. Having no more bioline, I just used more 25mm feeder line with slow drippers every 40cm or so. This got the system to the right speed of discharge (about 5-7 minutes for the full grey water system). It was working fine for a while, but now seems to be clogged up as not much at all is coming out of the holes in the bioline. I'd like to try to unclog if if possible and wonder if anybody knows how to do this. I'm already ready to give up on the stuff and just buy more variable drippers - they are cheap and much easier to control. Re: HOW DO I UNBLOCK MY IRRIGATION SYSTEM 3Nov 09, 2011 12:30 am Not good to mix different types of irrigation on the same line as well. That can compromise the integrity of the system in this case. They can not be unblocked. The pipe will need replacing. These still need a flush valve on the end and a must is to have a filter installed at the head of the line. Only ever connect more of the bioline. Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20182 Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone… 0 22761 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19517 |
