Browse Forums Landscape & Garden Design 1 Sep 29, 2011 12:36 pm Hi all we are installing some frameless glass for around the pool and I need to lay some concrete to bolt down my spigots (dyno bolt types, not core drill) to hold my glass panels. I am thinking of going 300mm wide by 400mm deep and it will be 10meters long. What I need to know is, is the depth enough?? Was also thinking of going down 1mtr every 1.5mtrs doing a 100diameter hole to basically stop the whole fence from rolling over. http://i749.photobucket.com/albums/xx137/01rickster/fence.jpg just a quick drawing of what it would look like basically. Thanks for your input in advance. Re: Frameless glass concrete footing depth please??? 2Nov 08, 2011 11:09 pm Get in touch with these guys http://glassboundaries.com.au/contact/ 2 4497 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10247 |
