Browse Forums Landscape & Garden Design 1 Sep 22, 2011 3:21 pm Hi All, I am chasing some treated pine logs (preferably 125mm in diameter and around 3m long) in the Perth area (preferably south of the river). I will be using them and some wire to build a trellis for holding our espaliered fruit trees. Can anyone recommend a place in Perth that stocks these size logs? Thanks, Chris DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6579 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52849 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10970 |
