How rain-proof are paved areas?
Here's our dilemma. The worst water-logged area around our house happens to be exactly where our ginormous water tank is with all of its glorious pipes etc., all squashed against the house wall.
There are really lots of very shallow pipes in this small and flat area. We are struggling for some falls, so the pipes are shallow and it is almost impossible to grade this area as the fence is only 2.2 m away.
So, an obvious option is to pour some concrete along the house slab, to protect the slab and prevent capillary action. But this would be pouring concrete over hard clay with plenty of 'important' piping underneath.
So, we were thinking that some large pavers could be a substitute, but only if cut very neatly and tightly around the pipes and sloped away. But what do we do with the joins? They would obviously let the heavy rain in (under the pavers). Can they be filled with some Sikaflex or similar to make them perform more like concrete? (even if we have to re-apply it every year or so). Or even put some builders plastic under the pavers. The area is only about 1.5 m2.
Help!!!!!!!
A Clay soil which is too dry is as bad as one that is too wet. Ordinary paving will keep enough moisture out
If you have a serious problem, you could perhaps install some ag pipe under your paving?
Kek, do you have any subsoil or other drainage somewhere?
Had another look at this today and this is actually more like a big dip. We can't build this up because of the weep holes. Whatever we install, it will have to be right under the weep holes
Just smash down some pavers and maybe do similar to Keks place with some gravel between them. Do them down on a good bed of yellow brickies sand and the pavers get easier to lay and drainage is better.
There will be no point in chasing a water proof option because no matter what you come up with, it won't work.
17
Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window…
13/06/2023
Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like…
15/12/2023
Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete…
