Browse Forums Landscape & Garden Design 1 Jan 31, 2008 1:52 pm Hi folks,
I've had a landscape designer produce a design that requires a number of either or both cement rendered retaining walls and timber retaining walls. Does anyone know the approximate costs per square metre (including labour) for a rendered block retaining wall and a timber retaining wall? None of the walls require engineering or council approval (the highest is just under 600mm high) and I'm looking for indicative Sydney prices. Thanks, Jamie Re: Retaining wall costs 2Jan 31, 2008 3:06 pm I'm in the process of getting a quote for a big timber retaining wall (30cm - 1.9m tall and about 15m long)
Will report back when I get the quote! (I'm expecting it to hurt... ) Building a Jandson Espirit in Pennant Hills "What is the use of a home, if you haven't got a tolerable planet to put it on?"Henry Daniel Thereau Re: Retaining wall costs 3Jan 31, 2008 6:03 pm a timber retaining wall with I beams (or H beams) at 1200mm centres varying in height from 1300mm to 800mm high at a length of approx 25 metres was $4500 here in melb. Re: Retaining wall costs 4Jan 31, 2008 7:43 pm It really depends a lot on the actual site - $4500 on one wall may be $3500 for the exact same finish size at another site. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5195 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16156 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
