Browse Forums Landscape & Garden Design 1 Aug 26, 2011 3:55 pm Does anyone know if there is a standard size for the aluminium slats used for front fences in between brick piers? Re: Front fences 2Aug 28, 2011 6:15 pm There are several sizes that you can get, depending on the look you are after. Sometimes shires put a permeability requirement on front boundary fences, which could determine the size slats and gaps you will need. Re: Front fences 3Aug 29, 2011 1:27 pm CA3105 There are several sizes that you can get, depending on the look you are after. Sometimes shires put a permeability requirement on front boundary fences, which could determine the size slats and gaps you will need. Thanks CA3105, better check council website. Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2862 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9070 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7379 |
