Browse Forums Landscape & Garden Design 1 Aug 21, 2011 10:09 pm I have a 15mx8m backyard all of which I would like to be grass ... And a row of trees at the back. What irrigation method would you recommend? I would like to install it myself Irrigation method 2Aug 21, 2011 10:57 pm There is only one responsible way. First where do you live. Can you afford to irrigate a large amount of lawn? Can you afford it in the future? Do you need lots of lawn? MP rotators on the lawn or rainbird gear drives. Garden: netafim 13mm techline AS subsurface. Any compromise on that is going to more than cost the initial offset of the savings during instalation. Water in WA in particular is going to be some of the most expensive in Australia. Plan now rather than work out how to afford change later. Make sure the turf is laid according to the turf thread so it costs as little as possible in all the years ahead. It will just be easy. Avoid seeded turf. Re: Irrigation method 3Aug 21, 2011 11:00 pm Thanks Fu. I am in SA. It's either concrete or lawn, and I'd much rather have lawn... Re: Irrigation method 4Aug 21, 2011 11:02 pm How do I work out how much $$$ watering our lawn is going to cost? Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20165 Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone… 0 21909 |
