Browse Forums Landscape & Garden Design 1 Aug 03, 2011 2:50 pm I need to end a retaining wall perpendicular to a brick wall. How do seal this joint or should it be OK to just butt it up against the wall? The wall will be backfilled with soil and I dont want it creeping through the joint, esp when it rains etc. Re: Joining Retaining Walls 2Aug 03, 2011 4:11 pm What material is the retaining wall made of? If it's brick or besser blocks etc you can coat the joint with a waterproofing agent available from most hardware stores. It will be hard to achieve a perfect waterproof seal if other materials like timber or mortar-less blocks are used for the retaining wall. Rgds Leonard. Re: Joining Retaining Walls 3Aug 03, 2011 4:20 pm One solution is to provide a better route for drainage than through the joint by putting gravel behind the wall with a drain at the bottom. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11116 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11759 |
