Browse Forums Landscape & Garden Design Re: Soakwell Help 7Jul 29, 2011 12:46 am The drainage will be fine but make sure you have several. I'd be looking to use ag pipe leading to the soak well rather than 90mm storm water pipe. It will handle it. Takes up the same space and allows additional drainage along the way. With our sands, gravel won't be needed around it. Just use the sock that covers the ag pipe. It'll be fine. Also not all down pipes flow the same amount of water.. My place is linked up almost the whole way round with both 90mm storm pipe and ag pipe. It can handle what comes off the roof and drain a flash flood in the garden in minutes after the rain stops. There is two I didn't connect and they are the only ones I have problems with. Those problems being they overflow onto the pavers. One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 656 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7931 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12512 |
