Browse Forums Landscape & Garden Design 1 Jul 11, 2011 9:46 pm Hi All, Finally moved in and now need to build some pathways on the sides of the house and need to know whether it is safe to install an ag pipe drainage system where there will be residual water against a slab. Picture below..... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your help would be greatly appreciated Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Is this a safe location for ag pipe?? Residual water? 2Jul 11, 2011 9:58 pm Looks fine to me. If it was me though I would lay the pipe on the bottom of the trench and surround the pie with 5mm gravel and then put the 20mm stone on top. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Is this a safe location for ag pipe?? Residual water? 3Jul 11, 2011 10:14 pm thanks bashworth.... so having the residual water around the (as there would be some left over after rain or watering) is ok around the the slab location? and what is the reasoning behind having smaller stones around the pipe? Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Is this a safe location for ag pipe?? Residual water? 4Jul 11, 2011 11:03 pm If the pipe is at the bottom of the trench the residual water will be minimal and as long as the underside of the slab is protected there shouldn't be a problem. The smaller gravel will 1.Provide better support for the pipe 2.Filter out fine dirt that gets washed through the larger stone, keeping it out of the pipe The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 2816 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 2730 Thanks for info, yes met with Power Utility, Builder's Site Supervisor and Electrician on site and aligned on the mains connection. Seems like the builder and Electrician… 2 9977 |
