Browse Forums Landscape & Garden Design 1 Jul 07, 2011 7:49 pm Hi all, The subject says it all really. I have a 900mm retaining wall built, the ag pipe is in, and I have covered it with about 200mm of crushed rock so far. I also have a whole bunch of house bricks that will be labour intensive and expensive to remove from the property due to access reasons. The question: Can I use broken brick parts (say 1/3 of a brick) in place of crushed rock to fill the remaining 700mm? Anyone see a problem with this? Cheers, HC Re: Retaining wall - Crushed brick instead of crushed rock 2Jul 07, 2011 7:53 pm Broken bricks will be fine. All you need is a well draining medium. it might be best to put some gravel on the top though to keep any soil from getting washed in and filling up the voids. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining wall - Crushed brick instead of crushed rock 3Jul 07, 2011 8:20 pm Awesome. Thanks for your feedback. Should I be worried if the brick has mortar attached to it? Could the end up blocking my ag pipe? HC Re: Retaining wall - Crushed brick instead of crushed rock 4Jul 07, 2011 9:19 pm mortar stuck to the bricks will be fine The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5194 Hi all, I have been looking at land in South Australia, that is on a slope however most of the core excavation is complete, with a flat area to place a house. The agent… 0 1411 |
