Browse Forums Landscape & Garden Design 1 Jan 21, 2008 8:53 am Hi all,
Here is one for those who have / the professionals amongst us. I am building a retaining wall using 190(mm) h*390 l*90 w blocks, sitting on a concrete reinforced foundation. Color of the blocks is a sandstone color, similar to this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ or this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wall will be 2 blocks high (390mm total), and not load bearing. Do I need to put mortar between the levels or can I use an adhesive (liquid nails or similar). If mortar, how can I color match it to the blocks, ie what type of cement, what type of sand, do I need a color additive etc etc. Thanks in advance Adrian B Re: Mortar color 2Jan 21, 2008 9:25 am Adrian, by the pics, they are the C&M brand. We've used them a few times and have had them about 5 courses high, plus capping, from memory...
They interlock together but we also used liquid nails for a bit of extra strength...The C&M ones are really easy to use... Good Luck. ![]() ![]() ![]() Re: Mortar color 4Jan 21, 2008 10:26 am Adrian, do the ones you want actually interlock??? Or are they more like besser blocks / bricks where mortar is definitely required? Thanks for the feedback Of course you would expect to get the bush-off treatment from their engineer they are paid by the builder what do you expect him to say? As 2870… 13 5904 ![]() Hi all, I just moved into a 1960’s block with brick veneer and was just wondering how worried I should be about the loose brick veneer and lack of mortar at the back of… 0 1623 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 1400 |
