Browse Forums Landscape & Garden Design 1 Jul 03, 2011 4:46 pm Hi Guys, Have a pool area that was perviously dominated by palms/trees that def. needs an "upgrade" (See pics) Any suggestions are appreciated...realise the pebbles/rocks def. need to be removed! small retaining wall/garden bed? Cheers! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on pool area 2Jul 03, 2011 5:27 pm can we see pics of the rest of the garden I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Advice on pool area 3Jul 03, 2011 6:00 pm mecha-wombat can we see pics of the rest of the garden Rest of garden is non-existent... going to base rest of garden off pool area...but happy to get some pics(its dark now, so will have to wait until tomorow) Cheers. Re: Advice on pool area 4Jul 03, 2011 7:55 pm Ok so you are starting from scratch so to speak Do you have a style of garden you like?? I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Advice on pool area 5Jul 04, 2011 6:35 am mecha-wombat Ok so you are starting from scratch so to speak Do you have a style of garden you like?? Not particularly - Basically just want to tidy it up, and make it look a little more inviting(Originally had a lot of those horrible cocos palms) Live in qld, so tropical-type look is what I think would work...i.e. some small palms Cheers Re: Advice on pool area 6Jul 04, 2011 5:20 pm yes those cocco palms are horrible i had some of them in my last two homes right near the pool had them removed but not before i had to buy and new pump and filter because of the nuts of the cocco palms finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Advice on pool area 8Jul 06, 2011 9:53 am keen Frangipani, Tiger grass, Bamboo. Good call on the tiger grass! So, remove all the old pebbles/rocks...new soil, tiger grass/bamboo etc and mulch(?) - The block is quite steep, and we get pretty bad run-off in this are of the backyard...so not sure how well mulch would last? Thanks! Re: Advice on pool area 10Jul 07, 2011 8:54 am Here is one idea, I would just plant in out anything large leaf. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Advice on pool area 12Jul 07, 2011 10:04 am rocks look like concrete coloured to look like sandstone But since you are in QLD I would be looking at ornamental ginger, Bird of paradise, clumping bamboo(could use that to block out the fence. As for Mulch if you get Treeloppers mulch I found it will handle runoff exceptionally well and tends to stay well knit I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Advice on pool area 13Jul 07, 2011 10:17 am mecha-wombat rocks look like concrete coloured to look like sandstone But since you are in QLD I would be looking at ornamental ginger, Bird of paradise, clumping bamboo(could use that to block out the fence. As for Mulch if you get Treeloppers mulch I found it will handle runoff exceptionally well and tends to stay well knit Cheers - Great suggestions! Re: Advice on pool area 14Jul 07, 2011 1:09 pm i have nothing to add execpt this should be your avatar: http://dubsism.files.wordpress.com/2010 ... .jpg?w=240 Re: Advice on pool area 15Jul 07, 2011 2:06 pm miteq i have nothing to add execpt this should be your avatar: http://dubsism.files.wordpress.com/2010 ... .jpg?w=240 hehe...yes, Simpsons best character...well run's a very close second to Homer! Re: Advice on pool area 16Jul 09, 2011 6:51 am Hi Guys, Well spent quite a few hours removing the rocks(What a PITA!), and Im now down to basically more rocks/cocos palm roots - Just after opinions on whether I should place a retaining wall butted up against the pool edge(In pics, where the existing concrete garden edge/drain is), to bring the level of the garden bed up, so I dont have to spend the next month digging out roots and rocks. Where the concrete edge is currently, I get a lot of water run off down towards the pool filter shed - Any suggestions?..maybe run som ag pipe/drainage gravel against the retaining wall? Anyways, appreciate any suggestions. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17908 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11035 |
