Browse Forums Landscape & Garden Design 1 Feb 27, 2013 2:56 pm Have just had two small trees removed from my courtyard. The guy who removed them said that I couldn't plant in the same place because of the roots of the old trees. But it is just a courtyard so not much space to play with. The trees removed were tea trees approx 2 mtrs high. The guy got out most of the bulk of the tree roots. Today I went through the area with pick axe and dug down about 30 cms. I removed some larger roots and a lot of smaller ones. Will this be enough to then plant in roughly the same spot? I am putting in lilli pillis. Have I done enough? Re: Planting new trees 2Mar 08, 2013 10:29 am The old roots make no difference at all. In fact they will be a long term source of nutrient and an excellent source of beneficial fungi which will pull that apart and feed to the new tree. Re: Planting new trees 3Mar 08, 2013 10:31 am Do you have to use a bloody lily pilly? So many better trees or shrubs. Being a court yard, you should think about something deciduous perhaps to let warm winter sun in and shade the hot summer sun A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 225912 A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 7089 |
