Browse Forums Landscape & Garden Design 1 Jun 07, 2011 12:59 pm G'day everyone, One of our lilly pillys (I know, I know!!! ) fell over in the cyclone. Well actually most of them did. This one was been tied up for about a month before the straps holding it broke. It seemed to be doing ok for a bit until it fell over again recently. This is the only one out of all the trees that is giving up trouble after all this time. It doesnt seem to be dying, so how long does a tree need to be staked/supported to be able to hold itself up again? It is about 3-4 meters high. Sandra Tree has fallen over, how long until it stands up again? 2Jun 07, 2011 4:02 pm Cut it back a third. Stake it. It might take a year. Seasol, molasses, powerfeed. Heavy layer of tree lopper mulch including what you cut off. Re: Tree has fallen over, how long until it stands up again? 4Jun 10, 2011 2:49 pm Might take less than a year. There is no way a time frame can be put on things like that. What makes the difference is the health of the soil. In a good soil I'd expect a fast recovery in under 6 months. Its a lot of root to regrow! Imagine what you see above the ground exists in a flatter format under the ground. Most has been torn or broken and that needs to regrow. It takes a while to regrow that volume. It still has to look after all the stuff above the ground too. Imagine we cut your arm off and still expect you to juggle Instead we will let you throw the ball up and down while your arm grows back Nurture that soil. It is what the plant will be using to produce new roots. Insulate it as best you can with thick raw mulch from a tree lopping contractor. humus rich compost under that. Old milk and molasses around the base as per the thread. Hi , I'm currently going through this now within the Whitehorse council which has a similar set of restrictions. We're having to make compromises with our floor plan due… 3 30668 of course there are legal avenues. You've already mentioned it. Sue them. I find it odd that lawyers wouldnt be willing to take on the case, given CCT evidence and… 1 23758 |
