Browse Forums Landscape & Garden Design 1 May 18, 2011 7:26 pm Hi Can anyone tell me how deep the storm water pipes from downpipes going to soak wells should be? Some of mine are ~1cm below the surface for the top level of the pipe and this does not seem adequate coverage for the pipe to me... Thanks in advance Re: Storm Water pipe depth 2May 18, 2011 8:27 pm there is no minimum. It is defined by the available fall. Would I be right in saying at the point where the pipe is only 1cm below ground this would be the furthest from the point of discharge. As they get closer to the POD the pipe will go lower into the ground. Re: Storm Water pipe depth 3May 18, 2011 9:37 pm B STAR As they get closer to the POD the pipe will go lower into the ground. Should go down at a slope of around 1:40 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Storm Water pipe depth 4May 18, 2011 10:03 pm The storm water drains should be a minimum of 100mm below natural soil level (measured from the top of the stormwater pipe). I believe this is covered in the BCA under Section 3.1.2.5 (Stormwater Drainage). Re: Storm Water pipe depth 5May 19, 2011 3:10 am Thanks all for your feedback. The pipe is not the furtherest from my soakwells - it is approx halfway along one of the sections. I have not dug to see what depth the rest are at yet... Trinity - do you know where I could see a copy of that section of the BCA? Might be what I need if it is referring to 90mm stormwater pipe. Re: Storm Water pipe depth 6May 19, 2011 9:18 pm Wandering Trinity - do you know where I could see a copy of that section of the BCA? Might be what I need if it is referring to 90mm stormwater pipe. Hi Wandering, My building inspector quoted this section in his report when we had similar issues. I don't have a copy of the BCA myself. However......I just googled and found a site that seems to have it. There's a bit more detail eg different depth requirements depending on if the pipe is below a path, or an area subject to light vehicular traffic. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7809 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6842 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10465 |
