Browse Forums Landscape & Garden Design 1 May 18, 2011 2:52 pm Hi gang Need some help... I am wanting to dig up and move a 7 year old, 3 mtr, conifer tree... can this be done??? if so how would i go about it??? Ie.. how big will i need to roots and thoughts on re-planting etc... Any help is greatly appreciated. Re: Moving a 3mtr, 7 year old tree??? 2May 26, 2011 8:45 pm I recently moved a guava tree using a dingo with a trencher attachment. First i pruned it right down until only a few branches with leaves were left. I then trenched around the base of the tree in a 0.7m square and went down about 0.5 deep and used a snatch strap to pull it down and drag it to a new spot. I dug a new hole using the same technique. once it was in place I used seasol to water it once a week. So far it looks like it may have worked, although time will tell. Its a bit rough but it would cos a fortune to pay someone to do it for you. Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10224 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72341 |
