Browse Forums Landscape & Garden Design 1 Apr 30, 2011 1:17 am Hi there, I'm sure someone here will be able to send me in the right direction - hopefully! We are building on an E class block and so the slab was raised 500mm according to engineers plans. After doing some reading on here, I'm thinking we should probably put concrete or stone path around the perimeter of the house. How does one go about working out what to do? With that sort of soil type if you ask for a design to include piers then I would also include void formers. That way you should reduce the chances of settlement and heave. 7 4633 Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7850 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35321 |
