DIY costs and complexity for Pebble Path?
Page 1 of 3
We are nearing the completion of construction and as sure as the sky is blue - we have just realized we are fast running out of budget to fund a lot of things that we initially wanted.
However we certainly do need a path on the side of the house as walking through sloppy mud is certainly going to dampen our new home experience.
So the question is;
Have any of you DIY a pebble path?
What was the complexity to do this - is it something a 'non' handyman can do?
What are the approximate costs p/sqm (white pebble with large concrete stepping stones)?
The below is what we would like our future yard to look like (but interested in the side paths specifically)
A tape measure, spirit level, string line, rubber mallet, and a wheelbarrow to mix the sand and cement are about all you need.
http://i459.photobucket.com/albums/qq311/EB_Photos_2009/SteppingStonePavers002a.jpg
http://i459.photobucket.com/albums/qq311/EB_Photos_2009/AirCondArea2ndMarch2011004a.jpg
One thing you may need to consider is access to your rear yard to complete your landscaping. I have left the narrow, (blind side) path to my house for last so that I can get my materials in and out without having to drag them over stepping stones and gravel.
Good luck.
I did a short stepping stone path around my Air-Cond Unit. I shopped around and picked up the pavers for a few bucks each and instead of spending up big on decorative pebbles, I used 20mm blue.
Good luck.
Good luck.
That looks very nice! I am looking at doing something similar along one side of my new house (almost finished!). I am a complete novice at gardening/landscaping and have never done anything like this before. However, I would like to give it a go. What kind of prep work do you need to do to the base soil before you add the stones on top? You say it was 20mm blue? Do you mean blue metal road base?
The soil was compacted with a plate compactor just to get it firm so it would not move too much.
The 20mm Blue is basically 20mm blue metal gravel. Some places refer to it as drainage gravel as well. It comes is varying sizes. 7-10mm, 20mm, etc.
I also put down a layer of weed mat before the gravel just to keep the weeds under control.
I was / still am a total novice.
Thats awesome KnockItDown...... it looks like it was pretty easy to do... how long did it take you to do and what was the total damage to your wallet?
20 pavers at $3.50 each = $70
1 tonne of gravel $59
8 bags of sand and cement $52
1/2 a roll of weed mat - Cant remember the price exactly but less than $10.
Total cost under $200.
A couple days to complete.
fantastic...thats certainly not going to break the bank but may do some damage to my back
great work and thanks for sharing - this is exactly the information that we were after
On the left hand side of the pics as you look at them, about 1m down at the base of the retaining wall is a 100mm Ag pipe.
No problems with drainage even with all of the heavy rain we have had.
http://i1116.photobucket.com/albums/k573/qonyx2010/IMG_9693.jpg
http://i1116.photobucket.com/albums/k573/qonyx2010/IMG_9704.jpg
http://i1116.photobucket.com/albums/k573/qonyx2010/IMG_9697.jpg
http://i1116.photobucket.com/albums/k573/qonyx2010/IMG_9744.jpg
I am planing to to exactly what KnockItDown has done. Looks like a most cost effective way of doing a stepping stone path.
Few questions for KnockItDown
I was wondering how was the end result to walk on and move bins and wheelbarrow?how is it holding up after couple of years?
But ... Do you need to put the stepping stones on cement ? My soil is sand, so a good base to start. I was planning to run it away slightly from the house and have the stepping stones fairly close together. Then put in the stones. Slight slope to rear and side so drainage is not problem.
Quote:
Thanks for all the advise. We are now in the house and I have since built the pebble, paver path with pics attached. All up cost was about $1200 which would have cost much more if i had to get someone else to do it (probably double) so thanks for the savings!!!!
Hi Q.
$1200 sounds a lot to me. What was the main cost.
Is this just for the stones and stepping stones ?
I'll be watching this thread as I'll be attempting something like this for our house when we move in! I'm also interested if (and how) you have to cement the paves/stepping stones into the ground?
Yes - would a sand base be just as good ?
Here's some pics:
Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path…
27/01/2024
2
Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to…
16/01/2024
Hi all Following the recent heavy rainfall in Sydney, I am keen on redirecting water away from the house's base as much as…
