Browse Forums Landscape & Garden Design 1 Apr 21, 2011 9:31 am Hi Guys, First post Just bought a new house last year and now finally getting around to starting some DIY projects around the place. First will be a new retaining wall in my backyard as the old one collapsed during a massive deluge of rain. Was poorly constructed with no drainage I can see Anyway, could someone please tell me what the function of this pipe is as it will need to be relocated slightly to make way for the new wall. Thanks heaps! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What is this PVC post in my backyard? 2Apr 21, 2011 11:09 am Hi Poida, Have a look at what that wire or lead is that's sticking out. It may be an electrical cable for planned garden lighting that never happened. I don't know why they would have had it up so high unless they were going to have bollards in the garden?? Anyway, folow it back and see if it's plugged into a junction point or something. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: What is this PVC post in my backyard? 3Apr 21, 2011 11:40 am Thanks SK, So many things the previous owners have done have left me scratching my head. There is a shed close by so they could have been planning to run power to it.... I'll dig carefully around it and see where it runs. Hopefully not directly under the concrete pathway! I was worried it was a ground spike to earth the house electrics..... Cheers Poida Re: What is this PVC post in my backyard? 4Apr 21, 2011 11:50 am No. They have to be very close to the meter, usually right under it. And they are metal spikes, not PVC. Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: What is this PVC post in my backyard? 5Apr 22, 2011 12:41 am I think if you put a data plug on the end and connect it to the intermanets you may find the secrets of life itself..... Whaoooaaaaa yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 DIY, Home Maintenance & Repair Please suggest a correct way to fix this issue. I want to remove frog mouth and fix it properly because roots are getting through frog mouth and blocking pipes. I am… 0 209 |
