Browse Forums Landscape & Garden Design 1 Mar 30, 2011 8:03 pm Check out these cool microscopic photos. It shows close up photos of leaves of different Buffalo grasses, and explains why the old style original buffalo was scratchy, and shows why most of the modern ones are soft. http://thelawnguide.com.au/lawn-varieti ... grass.html http://thelawnguide.com.au/lawn-varieti ... art-2.html http://thelawnguide.com.au Re: Microscopic photos of barbs of scratchy and soft buffalo 3Apr 05, 2011 1:11 am An independent guide or a disguised breeder guide? Great photos though Re: Microscopic photos of barbs of scratchy and soft buffalo 4Apr 14, 2011 9:15 am I think if you look at the site it is clear that the Lawn Guide writer does his own thing. Sure people can advertise, but he has his own opinions, and does not always agree with the advertisements. eg; Kenda Kikuyu is advertised, but if you look at the article for Male sterile Kikuyu types, it basically recommends against them, unless you have a lot of wear, like dogs or for use on sporting ovals. From what I understand, the site started of as a lawn care site for mowing contractors, and naturally developed into a much wider lawn web site. I think sharing research information from Australian Buffalo research like shade research etc by an independent web site is long over due. I think this one is definitely independent. Microscopic photos of barbs of scratchy and soft buffalo 5May 04, 2011 1:19 am That's cool then regardless I was just winding you up. It has some excellent info. Re: Microscopic photos of barbs of scratchy and soft buffalo 6May 06, 2011 11:40 pm Reminds me of Victorian Grasses around coastal and sandy swamps. Not something you want to run through but if tossed an iceburg lettuce into it and had someone on the other side... I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3302 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9884 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19968 |
