Browse Forums Landscape & Garden Design 1 Mar 29, 2011 10:19 am hi, I've a terracotta pot and plan to place in indoor for a small plant. How to paint it? I read that I need to put the sealer but before painting, after painting? Do i need to paint / sealer the inside of the pot? I've water based primer,sealer, undercoat all in one ( white ), can I use that? Can i use the water based acrylic paint after the primer? Thanks very much Re: How to paint terracotta pots? 2Mar 29, 2011 10:26 am There are sealers you can buy from Bunnings etc. Yates have one called 'Pot-a-seal', which is sprayed on, but there are some I've seen that are brushed on as well. We sealed the inside of all our outdoor pots, because the Terracotta is quite porous and it draws all the water and dries the soil out quite quickly. By sealing it, you help keep the soil moist. There are many links if you google "sealing terracotta pots". Re: How to paint terracotta pots? 3Mar 29, 2011 3:29 pm just Erin There are sealers you can buy from Bunnings etc. Yates have one called 'Pot-a-seal', which is sprayed on, but there are some I've seen that are brushed on as well. We sealed the inside of all our outdoor pots, because the Terracotta is quite porous and it draws all the water and dries the soil out quite quickly. By sealing it, you help keep the soil moist. There are many links if you google "sealing terracotta pots". I find the best way to seal pots is with Bondcrete which is available in Bunnings. Paint the inside of the pot otherwise the water gets into the pot and lifts the paint. Topiarius Re: How to paint terracotta pots? 4Mar 29, 2011 6:41 pm Yup, I use a product inside and out to seal first, then paint the outside. I posted details in a thread here somewhere. It wasn't bondcrete, it was called Pot & Ornament Sealer or something, but I got it at Bunnings. I'll see if I can find the thread - there's even a picture. Re: How to paint terracotta pots? 5Mar 29, 2011 6:45 pm The thread's here Nott: http://forum.homeone.com.au/viewtopic.php?f=19&t=29727&p=489242&hilit=pot+ornament+sealer#p489242 The brand is Bondall. 0 4690 Hi everyone I have a terracotta tiles roof When I climb inside the roof cavity I can feel that there is a draft inside the roof as the wind goes through the roof which is… 0 4345 We're looking at replacing the roof of a heritage listed home so it needs to be terracotta tiles, wondering if anyone has any recommendations, hints or… 0 1361 |
