Browse Forums Landscape & Garden Design 1 Mar 27, 2011 4:55 pm Hi all, hopefully someone can help me out Our house is near completion and I am trying to figure out what is going to happen outside. We need to put down top soil & lay some turf, once it is all down how much higher will the ground be? Re: How much height gained with top soil & grass 2Mar 27, 2011 5:16 pm If you are going to put a reasonable amount of topsoil then its going to be around 200mm higher than it is now. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How much height gained with top soil & grass 3Mar 28, 2011 11:16 am If you are concerned about height you could always dig a bit out. If you are going to add 200mm of top soil then get a 200mm scrape. Re: How much height gained with top soil & grass 4Mar 28, 2011 11:18 am We want the height, we need to pour our alfresco and I don't want much of a height difference from the floor to grass because of kids hurting themselves so curious what level to pour it at Re: How much height gained with top soil & grass 5Apr 06, 2011 2:06 am You can't lay topsoil down. Also use a certified organic compost way over "topsoil". Soils need to be turned through and mixed into what you have at present. This is explained in the two turf threads. Also what is incredibly essential is to add zeolite, perlite and spongolite to that mix. Vital for any soil in an urban environment. These will all be investments and not costs. The very things that in time to come, as in years ahead, will allow a garden or turf be problem free. I see many train wrecks being created and money wasted everyday. Lay down even 200mm of soil with out mixing it in and that will be the extent of the root zone. Come summer the plants (turf included) will stress and need a huge amount of water. Only to not be able to absorb the water because the heat in that shallow layer of soil will have died off. It takes around 4 weeks of favourable conditions for the fine feeder roots to regrow. We done our landscaping a year back using Couch, over the recent months I have noticed another type of grass growing with the Couch in a 2x2m radius. I'm thinking the… 0 9237 DIY, Home Maintenance & Repair Please help me to answer this question , it will help me a lot as i can go to buy confidently with your recommendation: I want to put synthetic turf in our backyard for… 0 4079 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 29208 |
