Browse Forums Landscape & Garden Design 1 Mar 26, 2011 9:21 pm hi just wondering if anyone had ideas about relative cost of things. I'm thinking of down the side of the house. the length is 20m and the width is 1.5m and these are the options, however I'm not sure about the costs: (pavers are 600 x 400) 1. artificial grass 2. Boral pavers laid as a paved path (1200mm wide) with pebbles on either side 3. a concrete path (done at time of driveway 1200mm wide) with pebbles on either side 4. Boral pavers laid as stepping stones with pebbles on either side....I figured even though you use less pavers this way it's more labour intense since you have to lay concrete for each paver...compared to just paving the whole 20m as a strip? Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: relative cost for a landscaper - 20m path down side of h 2Mar 26, 2011 10:09 pm Can't comment on costs much but after having the stepping stones I wouldn't do it again. The pebbles/gravel almost allways ends up getting pushed over the top of the stepping stones and you are forever having to fix it up after walking over it. A continuous strip or concrete is the better option. Re: relative cost for a landscaper - 20m path down side of h 3Mar 27, 2011 6:57 am Have you considered crushed granite instead of pavers or concrete? Any good architect or building designer will be able to tailor design a home to suit not just your block width but also the site aspect, orientation and your lifestyle. … 1 264 Hi all Following the recent heavy rainfall in Sydney, I am keen on redirecting water away from the house's base as much as… 0 6899 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12423 |
