Browse Forums Landscape & Garden Design 1 Mar 13, 2011 4:08 pm Hi, I found Fu's advice given on which hose to buy in this thread to be great viewtopic.php?f=19&t=32129&start=20&hilit=hose+eclipse but now i'm a tad confused as there appears to be 3 'eclipse' hoses to choose from .... Any ideas which one i should go for or are they all pretty much as good as one another?? Here are the candidates- nts eclipse (single layer) 15yr warranty http://www.cyclone.com.au/products/nts- ... 12mm-x-15m eclipse satin (6 layer) 20yr warranty http://www.cyclone.com.au/products/ecli ... 12mm-x-30m eclipse (3 layer) 15 yr warranty http://www.cyclone.com.au/products/ecli ... 12mm-x-30m Many thanks Re: Which Nylex Eclipse Hose? - there are 3 different ones? 2Apr 05, 2011 1:19 am We use the plain old NTS and it does the job well in conditions that would make your average garden hose scared. Gets a kink, give it a yank and it goes straight. Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17527 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5268 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6466 |
