Browse Forums Landscape & Garden Design 1 Mar 12, 2011 2:08 pm we have just lay some new turf can anyone tell me what watering sheclude is thanks finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: New turf 2Mar 12, 2011 2:31 pm Just keep the turf moist at all times until it takes root. How much watering depends on the temperature, hot = more cool = less. Re: New turf 3Mar 13, 2011 12:51 pm yes i realise to keep it moist as there are different methods one said very day for 20 minutes one said every three days and one said for a week while one said for two weeks,so all a bit confusing finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: New turf 4Mar 13, 2011 8:04 pm Yeah thats why i said keep it moist, depends on the weather, since you are in qld water morning and early evening until the soil under the sod is wet each time. Stick your finger in to judge. How long depends on your irrigation set up. Just follow that simple rule and forget times etc. Once you cant lift the turf up and it has rooted down water once a day for a week then every couple of days working up to once a week. Water so the top few inches of soil are moist, to check stick a screw driver in. Once you figure out how long it takes to wet the soil you can irrigate accordingly. Re: New turf 5Apr 05, 2011 2:13 am Yeah there is no rule of thumb and just keeping it moist is the aim. You need to check it for yourself to be sure. Over watering will wash away vital nutrients and under watering will , yeah you know. Once it is established to workout how much water it needs, ween it off the water and when it stresses and goes a bit rubbish, add a few minutes. Then ween it off again. Your lawn is as temperamental as a person and it will get by on less and less water if you train it They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5831 A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 6720 |
