Hi all
Ive just dug 12 holes about 30 to 40 cm deep and same wide, Is this deep enough ???
They are currently in pots about 15mm wide and are about 40cm high and look healthy.
My block has clayish soil and some buck shot at 40 cm. The block nextdoor has the same plants but are slow growing, they dont seem to water them or feed them.
What do I put in the hole with them?
Ive got potting mix, blood & bone and a sea weed concentrate liquid.
Can you please tell me what to do next?
I was told I must mix in some of the soil out of the hole with the potting mix. Not to plant them in just potting mix as they need to get used to the local soil???
Its been hot and windy and will be the same for a few more days. Is it OK to plant them now???
I was thinking of 50% potting mix 50% original soil and a hand full of blood & bone then some of the sea week stuff to water it in. (all shaken not stired)
Please can you give me the correct method of planting as I dont want them to die and have to start again.
Thanks for your time and help.
Cheers to all
KW........................
