Browse Forums Landscape & Garden Design 1 Jan 31, 2011 2:20 pm Hi all, I've been having trouble finding a place that sells second-hand/seconds sandstone pots or something that looks similar (but cheaper) I can't afford full-price sandstone pots but I love the look, texture and colour and haven't found anything that comes close. I am from Perth WA and don't mind travelling a long way to get the goods Thanks! Re: Sandstone Pots - Second-hand/Seconds or something simila 2Jan 31, 2011 4:57 pm mlg85 Hi all, I've been having trouble finding a place that sells second-hand/seconds sandstone pots or something that looks similar (but cheaper) I can't afford full-price sandstone pots but I love the look, texture and colour and haven't found anything that comes close. I am from Perth WA and don't mind travelling a long way to get the goods Thanks! Hi mlg 85,the best way to get the result you want is to get plastic pots of all sizes and cover them in P.V.A glue and roll them in sand. Around Perth there are so many colours of sand in the bush you will find the colour you want. If you are a bit artistic you can do a rough drawing on your pot and then doing a bit at a time you put glue for example on the roof of a house and cover in sand and when that is dry do the same on the walls of the house and then do the trees and plants but use different colours of sand to get a mural.If you want something with more texture,mix your paint with marble dust and as you do each section"comb"the wet paint to get the surface you want. Topiarius Re: Sandstone Pots - Second-hand/Seconds or something simila 3Jan 31, 2011 10:47 pm you can also buy liquid sandstone from Bunnings and paint it on terracotta pots to add the bands ask for some burnt umber, red oxide, and raw umber tint and mix up a drop or two in a little bit and create some bands like natural sandstone I went outside once. The graphics were alright, but the gameplay sucked! Settlement:22nd June Slab:27th August Frame:16th Sept Bricked:21st Oct Roof:24th Nov Linings HANDOVER23rd March! Re: Sandstone Pots - Second-hand/Seconds or something simila 5Feb 02, 2011 5:58 pm I'm going to give it a go too My toddler will love it and it will be great to have some things she's made in the garden. I think we might try using some random glitter and sequins too. Should we seal it on the outside with anything to stop it flaking? Re: Sandstone Pots - Second-hand/Seconds or something simila 6Feb 02, 2011 9:44 pm KerryF I'm going to give it a go too My toddler will love it and it will be great to have some things she's made in the garden. I think we might try using some random glitter and sequins too. Should we seal it on the outside with anything to stop it flaking? Bondcrete is the best for sealing,it goes on a milky colour but dries clear. If you have a pot with a nice finish you can coat the inside to stop the moisture coming through. Sequins look good if you coat the pot with Polyfiller. I use a spatular to spread it on and every so often put a touch of paint on the filler before you spread it on and it gives the effect of an old rendered wall that has matured with the weather. Topiarius Re: Sandstone Pots - Second-hand/Seconds or something simila 7Feb 03, 2011 1:24 pm Thanks Topiarius I can't wait to give it a go now! 0 4798 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12719 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15650 |
