Hi
Not sure if I am in the right forum or not
But has anyone in Baldivis put a bore in?
If so how far did you have to go down, and any advise would be good.
p.s. we are also on a hill not the flat
Browse Forums Landscape & Garden Design 1 Jan 17, 2011 4:49 pm Hi Not sure if I am in the right forum or not But has anyone in Baldivis put a bore in? If so how far did you have to go down, and any advise would be good. p.s. we are also on a hill not the flat My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 2Jan 17, 2011 6:08 pm You can get a pretty good account of the water table depth on your property by using the link below. Its the WA department of Water map of the water table. Make sure you turn on your internet's popups temporarily in order to get your information window to pop up when you have selected your property/lot from the map. Zoom and pan in until you can select your property then use the "ruler icon" to get the water depth info on another window. http://www.water.wa.gov.au/idelve/gwa/ Hope that helps. Raz Re: BORE IN BALDIVIS WA 3Jan 17, 2011 6:47 pm Razza You can get a pretty good account of the water table depth on your property by using the link below. Its the WA department of Water map of the water table. Make sure you turn on your internet's popups temporarily in order to get your information window to pop up when you have selected your property/lot from the map. Zoom and pan in until you can select your property then use the "ruler icon" to get the water depth info on another window. http://www.water.wa.gov.au/idelve/gwa/ Hope that helps. Raz Thanks Raz Think we might be going down ALONG way Have no idea what the cost would be, has anyone had a good bore company put theirs in? We put one in ourselves in our last place but that was 18yrs ago and there is noway we be doing that again My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 5Jan 22, 2011 1:15 am Becareful with bores around Perth. We are drawing on so much water from the water table that many are becoming toxic. There are areas this is most likely to happen but sooner or later most bore owners will be faced with a situation like that unless we change gardening and irrigation habits. Re: BORE IN BALDIVIS WA 6Jan 22, 2011 8:17 am Even with a bore you can only water on your watering days that the water board have given you My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM BORE IN BALDIVIS WA 7Jan 22, 2011 10:19 am Yep, 3days a week. Many rural bore owners now have restrictions on how much can be used. Water Corp and Dept Water install water meters and monitor them. Re: BORE IN BALDIVIS WA 8Jan 22, 2011 11:44 am Im not rural, but we have a timer so it would set to a certain time, dont even know if we will end up with a bore yet, Thats why Im trying to find out if anyone has a rough idea how much they cost in Baldivis My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 9Jan 22, 2011 2:30 pm hey camyperth most bore drillers around perth charge btn $80-$110/m to bore down. then you need a good pump etc and power to the bore. viewtopic.php?f=31&t=43238 building with kerdels in gabbadah, wa block purchased april 2010 signed with builder oct 2010 papers signed jan 2011 prestart done 17/01/2011 Re: BORE IN BALDIVIS WA 10Jan 22, 2011 3:30 pm gabbybuild10 hey camyperth most bore drillers around perth charge btn $80-$110/m to bore down. then you need a good pump etc and power to the bore. Thanks for that info gabbybuild10, out comes the calculator My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 11Jan 22, 2011 3:33 pm Huuumm, have to think about that one, think we would be looking at $7-8000, we are about 60mtrs to water My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 12Jan 22, 2011 5:41 pm Razza You can get a pretty good account of the water table depth on your property by using the link below. Its the WA department of Water map of the water table. Make sure you turn on your internet's popups temporarily in order to get your information window to pop up when you have selected your property/lot from the map. Zoom and pan in until you can select your property then use the "ruler icon" to get the water depth info on another window. http://www.water.wa.gov.au/idelve/gwa/ Hope that helps. Raz Excellent tool !! Doesn't cover out to our block though Oh well, maybe it will by the time we get around to building in the next decade Re: BORE IN BALDIVIS WA 13Jan 22, 2011 7:26 pm Maya_Papaya Razza You can get a pretty good account of the water table depth on your property by using the link below. Its the WA department of Water map of the water table. Make sure you turn on your internet's popups temporarily in order to get your information window to pop up when you have selected your property/lot from the map. Zoom and pan in until you can select your property then use the "ruler icon" to get the water depth info on another window. http://www.water.wa.gov.au/idelve/gwa/ Hope that helps. Raz Excellent tool !! Doesn't cover out to our block though Oh well, maybe it will by the time we get around to building in the next decade long time no hear maya-papaya, thought you must have given up. Have you picked a house yet My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 14Jan 22, 2011 7:52 pm Hey camyperth Yeah, things stalled there for a while. Kinda back on track. I think we've picked a house. You'd have to ask my OH Re: BORE IN BALDIVIS WA 15Jan 22, 2011 8:19 pm Maya_Papaya Hey camyperth Yeah, things stalled there for a while. Kinda back on track. I think we've picked a house. You'd have to ask my OH Like that is it So what do you think,,, you have to picked? My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 16Jan 22, 2011 9:01 pm I think we're sticking with "V". Still nutting out details with the plan Re: BORE IN BALDIVIS WA 17Jan 22, 2011 10:04 pm Maya_Papaya I think we're sticking with "V". Still nutting out details with the plan Thats good, I will watch out for your build or let me know when something happens My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: BORE IN BALDIVIS WA 18Jan 23, 2011 9:30 am I've been looking at bores myself, according to the water site we have about 15 meters to the water table. I haven't gotten any quotes yet though. does anyone have an idea on the running cost difference between a bore and just using scheme water. Re: BORE IN BALDIVIS WA 19Feb 05, 2011 7:20 pm iduno I've been looking at bores myself, according to the water site we have about 15 meters to the water table. I haven't gotten any quotes yet though. does anyone have an idea on the running cost difference between a bore and just using scheme water. We had a bore in our last place, we ran it the 3 days a week like the water board said you can, Our elec bills where hardly anything and of course no water bill (about $35pryr for the whole houses water), used so much water so far since we put the lawn in, could be looking at a vvvvvvvvvvvery big water bill this year My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM there should be ss cable so you can pull up bore pump for service 1 3162 |
