Browse Forums Landscape & Garden Design Re: Retaining Wall Cost - Who is Responsible? 5Jan 12, 2011 3:02 pm http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Retaining Wall Cost - Who is Responsible? 9Jan 18, 2011 9:47 am the_milesy Given that they are going to be your neighbor, try asking them? The last thing you want is a dispute with your neighbors. They may not even be aware that it has happened. All they probably need to do is put in a aggie drain or similar. They may even plan / be in the process of putting something in. If they refuse and it does get out of hand, your well in your rights to dispute it. But you will probably end up in the courts. Once again, I wouldn't want a relationship like that with a new neighbor. This^^^^^^^ As a land owner you are responsible for water thats falls on and runs off that piece of land. Better to talk to neighbors first and try to sort things out before letting problems arise and get out of and. It might be something their builder/contractor has to rectify. FYI retaining walls under 600mm above ground (in Vic) do not require engineer designing, but they still require adequate drainage installed Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16160 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
