Browse Forums Landscape & Garden Design Re: Timber seating 12Dec 23, 2010 11:32 pm That one slat at the front sticking out ? wouldnt bother about it, its only the thickness of ya boards 22mm but if your plastering the front put a 10mm aluminium strip below the first slat then its only 12mm sticking out Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16122 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6247 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3358 |
