Browse Forums Landscape & Garden Design Re: Oh No! Whats wrong with my turf?! 15Nov 27, 2010 6:53 pm I can't condone the recommendation to poison everything and start again. If I did, I would have recommended it. It would be a case of using poisons for the wrong reasons. To me that would be a waste of money. They is enough there to bring things back and with good diligent care it is doable. Resist the urge to use chemical fertilisers on it. If something is not going well in the garden, the last thing that should be done is to fertilise it. You don't go into a hospital and take someone from a bed and get them to run a marathon. I have posted what needs to be done and it will be fine Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 2 31344 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18298 |
