Browse Forums Landscape & Garden Design 1 Nov 05, 2010 6:38 pm If I want to espalier lemon and lime trees - how far apart is the maximum recommended distance for the posts? 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Espalier question 2Nov 05, 2010 7:38 pm It will depend on what you are going to use and how much room you have You could do a flash one that is anywhere from 2m to 3.5 or a little more if you wanted. You could go even wider too I guess. Are you going to run wire between? Or use a trellis? Are you going to use timber posts or galv steel? I'd use some galv steel and then run galv cable between them. The Grandmaster of the hedge shears, Toparious, will have some different ideas too when he pops in Re: Espalier question 3Nov 05, 2010 7:47 pm Thanks Fu. I'm thinking wooden posts so that I can then put some lattice on top to block my new neighbours view of my outdoor area. Not decided on the 'roping' either fishing line or wire or something. I want to cover about 10-12 m of fencing with it - it might depend on the lattice that I want to put at the top though as to distances but I was thinking of lemon/lime/lemon/lime so 4 plants along the distance I'm still throwing up idea's 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Espalier question 4Nov 05, 2010 7:57 pm I reckon some 35x35 gavl square tube would be the go. Local steel shop would be able to cut it to size you need. Then run galv cable about 300mm apart maybe 400mm apart. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9971 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 1 13128 |
