Browse Forums Landscape & Garden Design 1 Oct 29, 2010 11:35 pm We're just finishing off a large extension to our home and are expecting the concreter to come back next week to pour our perimeter paths. We have our garden tap on the rear wall of the house then there will be the 1m concrete path and then we want approx 70m2 of turf with a garden bed and planting along the fenceline. We can't afford to put in anything too special in the way of an irrigation system just yet but should we be considering at least putting some sort of conduit or pipe under the path before it is concreted so we have the option of adding a watering system at a later date? We're in Adelaide and have recently had our watering restrictions relaxed in anticipation of the new desal plant being finished. Any suggestions would be appreciated. Re: Conduit or irrigation pipes under concrete perimeter pat 2Oct 29, 2010 11:49 pm Drop some 100 or 90 mm storm water 400 under paths and 600 under drives. Map where they are. Tape the ends to keep the pipe clear of debris and bury till you are ready to dig up and slot the pipes through it Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12510 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12769 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20177 |
