Browse Forums Landscape & Garden Design Re: Paving ideas needed, get in here! 3Nov 22, 2007 12:24 pm **Phoenix** Al the Nubrick pavers that you already have, have they been down long? I ask that as they might have faded, so to try and match them up to a new batch to continue it on to the garage might look a bit funny. They had been down a few years, and stacked for 2. If I buy the same again, I would mix them in randomly to try to avoid a dark patch/light patch. Plus, being two coloured already, hopefully a colour change won't be too noticable **Phoenix** What about using them as a border, and using another colour throughout the middle and carry that through. Ddn't think of that, but I may have a lot left over. Better check... **Phoenix** Also is the initial part of the driveway at the same level as the second piece of concrete at the side of the house? The reason behind this question is that it might be nice to carry the paving from the front driveway, down the side of the house and up to the garage at the back and the pergola.... Driveway and slab are the same level, the entire way through. The garage is higher than the slab, but being a seperated area (sort of), I can just pave uphill to suit. The rest of the driveway will be done eventually......money and inclination permitting. At the moment I plan just to do up to the gate at the end of the driveway and use it as a seperator. I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12384 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
