Advice on roses and buxus hedge during renovation
We will start renovations hopefully in January and there are 6 standard iceberg roses and a beautiful buxus hedge close to the house. I am afraid they will get damaged by the builders.
Is it possible for someone with a "black thumb" to keep the plants alive in pots?
How big would the pots need to be and what potting mix should i use?
They will be homeless for up to a year.
I have been told to move them now, before it gets too hot?
Is it worth my while or should I give the plants away? It would be a shame for them to die!
Would appreciate any advice. Thanks
Any other thoughts?
You will need some of those floppy big buckets with handles and small small cheap plastic buckets (about $1 each)
Drill holes in the bottom.
Mix the bulk potting mix and coir mulch together to make up your mix.
Clip the buxus back 1/3. This means there is 1/3rd less foliage they need to take care of after you rip their legs off
The roses, well they are tougher than Arnold Schwarzenegger in his prime. Clip them also like you did back in July. Same reason, less to look after.
Then to remove them, you need a precision instrument. That will be a really sharp spade
Now that the spade will go through the roots easier than Shane Warne going through the English batting line up, you have made the job pretty easy. You will need some secateurs now to trim up the roots a bit. Then pop them in the makeshift pots and you're done other than a dose of molasses and seasol
The coir peat makes for better water holding capacity and also makes rewetting the pots really easy through the summer. Try not to let them dry out especially in the first 6-8 weeks. Try pop them under shade for a few weeks or reduce the sun they get while they recover.
Sprinkle some seamungus around the tops of the pots.
While some of that is not ideal, it will get you a result on a budget and quick.
The roses will all survive, the buxus, well you might lose a few.
Look to do a bunch of cuttings from them also. You can use what you clip off them
Now to show you how much of a novice I am...
How big do I need the pots for the roses (1m high standards)? The buxus go in the smaller buckets?
Should I keep the plants in the shade after the first 8 weeks, or back into the sun. They are currently facing south, in full sun. I think I read somewhere that some plants don't like to face a different direction after they are moved!?
I will do a google search on "seamungus", "coir mulch", and molasses for plants!??
How long should the cuttings be for the buxus - I will definitely do lots of those.
Thanks for your help
Roses are made up of two plants stuck together to make one good plant. The rootstock is very strong but has rubbish flowers. The flowering top bit has rubbish roots but wonderful flowers
Use the bigger floppy bucket things for the standard roses and the cheapo buckets for the buxus.
4
Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying…
11/03/2024
2
I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major…
20/06/2023
9
i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were…
