Browse Forums Landscape & Garden Design 1 Oct 06, 2010 1:23 pm We're now in the final research stages of our landscaping, but we've still got a couple of stray parts of concrete left behind by the driveway guy, and we'd like to know: What's the best way to remove it from the ground ? Do you need a pick to break it up ? Is there a solvent/chemical to lift it away ? Then we've gotta find a way to remove it - might have to be a run to the waste transfer station Re: How to remove concrete from the ground before landscapin 2Oct 06, 2010 1:27 pm sledgehammer for small chunks - jackhammer for big ones How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6105 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12036 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7210 |
