Browse Forums Landscape & Garden Design 1 Sep 02, 2010 5:54 pm At the moment, our back yard is all mud, and has been dug out to a lower level than the neighbours gardens, so it fills with puddles when it rains. We need to fill it in with something, and have some type of surface that we will be able to walk on without coating our shoes and pants in mud. In future we will deck the area, but money doesn't allow for that at the moment. What are our options? Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: Temporary Back Garden Solution 2Sep 02, 2010 8:43 pm Thats a hard one. The major problem is the drainage issue you will have when it rains. Can you run some temporary pipes with pits (drainage pits)? You will have to run them somewhere though????? Depending on your council regulations etc you might be able to look into running into stormwater. But check with the powers that be first. All comes down to how much water comes in from the neighbours too. Is it a constant large amount, a trickle or only when you have a down pour? When you have mud building up, it doesnt actually take a lot of water to make major drama with mud. If its not so bad just put some cheap turf down, like kikuyu? That way you wont have to worry to much about having to be quick with your deck. Re: Temporary Back Garden Solution 3Sep 02, 2010 11:29 pm Get onto your local tree bloke for some mulch Failing that, this is the very circumstance where weed mat is used. Please remove it before your garden goes in though Re: Temporary Back Garden Solution 4Sep 04, 2010 3:45 pm Crushed rock maybe????? Forrester 43sq We have our keys (3/6/11) Now it's time to decorate (that's the fun part.lol) https://forum.homeone.com.au/viewtopic.php?f=31&t=37598 Re: Temporary Back Garden Solution 5Sep 06, 2010 3:43 pm Weed Mat and mulch both seem like great ideas Thanks! Now just need to fill in all the holes. Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 17069 Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3983 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1893 |
