Browse Forums Landscape & Garden Design Re: Can you secure a tree to your property? 21Aug 10, 2010 1:07 am Na, you can sort the bloom over the coming years yourself Get the one that has a nice shape you can work with If you prune it to shape someone will be even less likely to nick it having seen the recent clean cuts on it Sometimes we cut back plants in high theft risk areas so they don't look so good at first. Make sure noting jumps out you. Remove any tags as well. Re: Can you secure a tree to your property? 22Aug 10, 2010 1:08 am Re: Can you secure a tree to your property? 23Aug 10, 2010 9:28 am ok we might get one soon then. at the cute little ninja! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Can you secure a tree to your property? 24Aug 10, 2010 9:37 am Re: Can you secure a tree to your property? 25Aug 11, 2010 3:28 pm Is there anything nearby you can secure it to? You might be able to do something with a bike chain or two. As in, mine is a kind of spiral that'd work around the tree trunk, and then another one to attach it to a patio post or very heavy object... You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16148 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1697 The setback from the kerb is 4m. It is council land to provide an area for services like sewer main, gas mains, water mains, underground power or poles for overhead power,… 4 2398 |
