Browse Forums Landscape & Garden Design 1 Jul 29, 2010 4:27 pm Finally some common sense from the vic government; http://www.weeklytimesnow.com.au/articl ... -news.html From sept 1 you can water new warm season turf for 28 days to get the grass established. Re: New turf water restrictions eased for Melbourne!!! 2Aug 10, 2010 2:25 am This is good news. Water in the morning and evening if you have to. Avoid high evaporation times. Also make the most of the water and you East coast tyoes all the way over thheeeeerrreeeee :0 yse the hose a bit. Have a browse of my hand watering guide i posted, it's here somewhere and try not to use the old nozzle. it mists water too much. A soft spray and water is best applied slowly to an area. Try not to flood it. A bit at a time and keep coming back to the same areas over and over. This way run off is kept to a minimum. They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5900 I ended up going with 'Andrew Belic Construction Co.' https://www.instagram.com/andrewbelicconstruction/ 2 59686 if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4192 |
