Browse Forums Landscape & Garden Design 1 Oct 24, 2007 6:19 pm can anyone help with my native frangipanis? they were meant to be planted ages ago but the cut and fill changed on our house. they are in buckets in the backyard at the moment and while they were fine to begin with they are now languishing badly. I have 3 and one is almost gone completely and now the other two are dropping leaves when they should be flowering. Any suggestions (other than planting them) to keep them going another 4 weeks. Just build it the way I want and everything will be okay. Re: DYING NATIVE FRANGIPANI'S 2Oct 24, 2007 6:27 pm Have you got big holes in the buckets for good drainage????
They don’t like wet feet…… (wet roots;) they need good loamy soil and good drainage! Have you done this? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: DYING NATIVE FRANGIPANI'S 3Oct 24, 2007 6:28 pm What do you mean by 'buckets'? Do they have drainage holes etc.?
Native frangipani's often fail to thrive for no particular reason ( according to Don Burke) They grow into a fairly big tree - approx 10 metres X 8 metres. Do you have the room for three of them? Re: DYING NATIVE FRANGIPANI'S 5Oct 24, 2007 9:14 pm Hymenosporum flavum.
very big trees and they look so great it would be a shame to loose any. How have they been looking sick? what are the leaves looking like? are they yellowing, then going all brown on the margines and then dropping? are they just shedding healthy looking leaves? Make sure you not only address the drainage but you use a good quality potting mix rather than any other soil. Only potting mix will be of a benifit to a plant in a contained environment such as a bucket. at least make sure it has the ticks on the bag. Black ticks are not going to drain the plant of nutrients and red ticks will be best. That means the plant is getting looked after much better. Re: DYING NATIVE FRANGIPANI'S 6Oct 24, 2007 9:16 pm better mention that the use of "seasol" (not anyother seaweed product) will be of great benifit to your plants. use it every two weeks and they should strat to change to a healthier state Re: DYING NATIVE FRANGIPANI'S 7Oct 24, 2007 9:21 pm Yeah…..Love that Seasol!!!!
I dug up my lime tress, broke a few tap roots, trimmed them back and hit them with Seasol…….6 weeks later they STILL have small limes on them and there doing great!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: DYING NATIVE FRANGIPANI'S 8Oct 24, 2007 10:09 pm I might mention that they don't always grow to a big size like the do in say QLD or Nor' est coastal NSW.
eg. here in Perth they may only grow to 8-10m. You would be able to use these in small gardens in say melbourne or adelaide. the soil and climate isn't going to generally allow it to get to it's tropical size. Re: DYING NATIVE FRANGIPANI'S 9Oct 25, 2007 8:51 pm They won't grow as high but will still have the 'spread' Re: DYING NATIVE FRANGIPANI'S 10Oct 26, 2007 12:41 am over here in Perth most examples i have seen have all been small in height and narrow. There used to be a good example out the front of Waldeks in kingsley.
Either way they are such fantastic trees. Re: DYING NATIVE FRANGIPANI'S 11Oct 26, 2007 6:51 pm I had one in the backyard at my old house in Sydney, it was planted in 1973. It was about 6-7 metres high and had a spread of about 10 metres Re: DYING NATIVE FRANGIPANI'S 12Oct 26, 2007 6:58 pm POSER!!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: DYING NATIVE FRANGIPANI'S 14Oct 30, 2007 4:03 pm well i repotted them in an attempt to dry them out - then the storms hit in Brisbane and they are wetter than ever.
Then we found termites in the garden of the house we rent so i had to throw all my plants out because i couldnt take them with us to the new house filled with termites.... Just build it the way I want and everything will be okay. Re: DYING NATIVE FRANGIPANI'S 15Oct 30, 2007 6:08 pm bmp Then we found termites in the garden of the house we rent so i had to throw all my plants out because i couldnt take them with us to the new house filled with termites.... They are not neccesarily the 'house eating' type - there are only three of hundreds of types of termites that eat the timbers in your home. Most gardens will probably have perfectly nice harmless termites. Re: DYING NATIVE FRANGIPANI'S 17Nov 15, 2007 7:19 am Hey! I tried Seasol - nobobdy warned me about the smell. I can't go into my garden without gagging
And now they have odd raised black spots on the leaves and branches that i can't find mention of in my garden book - does anyone know what they might be? They can be pushed off rather easily. Just build it the way I want and everything will be okay. Re: DYING NATIVE FRANGIPANI'S 18Nov 19, 2007 9:34 pm It doesn't sound too cool.
These may be something like bacterial leaf spot or maybe a fungal disease such as anthracnose. This appears on Mangos in a similar fashion. Starting to sound more trouble than it's worth if it is bacterial then there isn't much you can do. You would use a systemic fungicide to offer some chance of recovery from a fungal disease like that. something like "fongarid" or a phosphoric acid based treatment such as yates anti-rot. (there is a cheaper alternative but it escapes me right now). over all tthings like that happen to a weak plant so stick with it. the seasol shouldn't smell that strong! Just a cap if that into a watering can. The smell should be short lived and the benifits of using it will far out weigh the smelly side effects. better off getting ithem stronger if you want to keep them. other wise give up on them and just buy some new ones later when you go to plant them. EDIT!>>>> what am I saying Helps if I read what you wrote a bit more Those raised bumps are scale. They feed on the sap and again would be an indication of a weak plant if they are in any great numbers. ants can often be responsible for them to start with as they farm them for the sugary secretions like we farm cows for milk. any treatment for scale should be accompanied by an ant treatment if you notice lots around as well (on the plant that is ) you need to use an insecticide such maldison. this is sold in a product made by a queensland mob called Chemspray. look for an orange box. Now this stuff is nasty and shouldn't be used without proper protection. i won't use it. i have read documents in the past that mention Maldison as being similar to a human nerve agent used by some not cool people. the only thing seperating us from the insects it treats is one single carbon atom in the molecular structure! As far as using white oil to treat scale that is W.O.F.T.A.M. (Waste Of F%$king Time And Money ) I don't know of any commercial nursery using this as an effective treatment. the above antiscal product has white oil in it but that is there I recon to make you feel better about using it Maldison is about the only truely effective insecticide for scale. rogor and confidor don't work too well. There are organic treatments too and I will post a new thread on that. Fig Landscapes has produced an e-book and native plant index, available for purchase from their website. It's a great resource, full of inspiration and tips. Another… 1 12220 |
