Browse Forums Landscape & Garden Design Re: I need a privacy fence that lets the breeze through 2May 30, 2010 7:31 pm That's a tall order. Usually a fence is open to some degree to let the breeze through, or closed up and the breeze has to find other ways around. You can't really have both. If you really want the breeze, then you will have to sacrifice the late night skinny dipping! Re: I need a privacy fence that lets the breeze through 3May 31, 2010 8:07 am If it's not a pool fence you can use horizontal slats. Slats applied to either side of posts and offset. This will allow air flow and privacy Landscape Design & Construction http://cherub.squarespace.com/ Re: I need a privacy fence that lets the breeze through 6Jun 04, 2010 12:18 pm A 1.8m high solid fence ie. colorbond isn't going to completely stop the wind from entering the space behind ... it will simply sweep up and over it. Built a Tribeca 44 with the Big M Sales Accept 15/06/09, Contract Signed 24/09/09, Site Start 23/11/09, Slab 11/12/09, Frame 12/01/10, Roof 20/01/10, Lock-up 30/03/10, Fixing 30/04/10, Handover 27/08/10. Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 3954 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 |
