Browse Forums Landscape & Garden Design 1 Oct 08, 2007 6:32 pm I intend to have some hardwired garden lighting installed. As a general rule of thumb, how many lights (of a brick type) would I need to install in a brick retaining wall of approx. 17.2m length. The lighting will be used for path/walk area Re: Garden Lighting 2Oct 09, 2007 1:42 pm ![]() I intend to have some hardwired garden lighting installed. As a general rule of thumb, how many lights (of a brick type) would I need to install in a brick retaining wall of approx. 17.2m length. The lighting will be used for path/walk area Michael, I'd say one every 3m-4m or so, so about 4-5 lights all up. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 31948 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 10509 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 10593 ![]() |
