Browse Forums Landscape & Garden Design Re: Tree removal 9Sep 28, 2007 1:45 pm Also, talk to a local tree removal specialist, as they will be well-versed in the local council regs, and know the right people to talk to. Often times they will know how to gain permission easily, if it may be one that you might struggle with.[/quote]
Thanks for that! Rang a local one today and they said they'd come around and have a look and help with the permit. They also said they deal with my council a lot and the process is usually pretty quick and painless. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6560 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6916 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10457 |
