Browse Forums Landscape & Garden Design 1 Mar 13, 2010 3:31 pm Hi All Is it safe to use treated pine sleepers for the walls on a raised garden bed for a vegie patch? Not sure if the chemicals will leach out. If it is not safe then can anyone suggest what would be a good alternative to use? cheers Re: Treated Pine Sleepers for Vegie garden dorders 2Mar 13, 2010 5:19 pm I'll say no, and a few others will say yes. I am fairly sure it is allowed but would I do it for A veggie bed? No I prefer the use of the metal cory raised beds. Here in WA limestone is an easy to work with alternative. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52856 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 |
