Browse Forums Landscape & Garden Design Re: Tough low groundcover recommendation needed 13Mar 08, 2010 9:46 pm ![]() kek that thyme is a fantastic idea. Marjoram also. Bloody flick weed and Oxalis ![]() You're not wrong, Fu. The local wholesale nursery is infested with those two weeds. I overheard one of their landscaper customers cursing as he's pulling the weeds out of each plant he was buying. Re: Tough low groundcover recommendation needed 15Mar 08, 2010 10:20 pm Avoid composted mulches. The goodness has already gone and you end up applying a mulch that holds a heap of water close to the surface, a no no in mulch world. Mulch is so much more than just holding water in the soil for longer. It is also the very best source of fertiliser in a far more available and eco friendly way. It is also what helps create new soil. Something we must learn how to do ![]() Re: Tough low groundcover recommendation needed 16Mar 09, 2010 7:31 pm ![]() Why was he buying it? I didn't bother to ask, but perhaps it was because he couldn't find the species elsewhere close by and was working on a Saturday. He was saying it was almost not worth buying. Re: Tough low groundcover recommendation needed 17Mar 09, 2010 9:43 pm ![]() ![]() jamiet, do they deliver ? Yes they do 7 days a week. It might be a bit pricey for you because you're on the other side of Sydney. Closer to you Southies is Menai Sand and Soil. They have a similar leaf mulch and also a Forest Floor mulch which appears to be leaf mulch that has been composted for 6 months: http://www.menaisandsoil.com.au/mulches.htm Fantastic! ![]() ![]() ![]() ![]() Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Tough low groundcover recommendation needed 19Mar 11, 2010 3:14 pm Looks like it, Nott. It gets little white flowers all over too, like this one: http://blog.mindbites.com/wp-content/uploads/myoporumparvifolium.jpg Very pretty! I'm plotting to kill off the grass on our nature strip and plant some of this instead, among other things. ![]() Re: Tough low groundcover recommendation needed 20Mar 11, 2010 6:03 pm Thanks Kek. I just found the pic is really vague. I also looked up My ~ Po~ in google b4 , also in nursery. However, the foliage in ur pic seems much larger and thicker than those I see in nursery-- which are a bit "needle" like I'm plannint to do the same, cos I really don't want to mow the strip and the weed is so "powerful" here! Are u using the white form / pink form? I always need to pull out the Kikuyu in the garden bed at the backyard. Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 17688 Hi guys, We are in the planning stage pre: final approval for our build. Now, we opted to have the AC unit out so we can place the rainwater tank closer to the house… 0 8958 |
