Browse Forums Landscape & Garden Design Re: Water timer with thermometer 2Mar 02, 2010 6:35 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Water timer with thermometer 3Mar 02, 2010 6:46 am Where you are coming from is where you are going to... Re: Water timer with thermometer 5Mar 02, 2010 12:17 pm Landscape Design & Construction http://cherub.squarespace.com/ Re: Water timer with thermometer 7Mar 02, 2010 7:52 pm That is going to be tricky. You would use the things cherub suggested. The only thing I can think of is using a weather temp sensor or a suitable thermostat. http://shop.weatherzone.com.au/index.ph ... cts_id=115 You would need to rewire the alarm to trigger the solenoid. http://shop.weatherzone.com.au/index.ph ... ucts_id=76 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10638 4 10822 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28323 |
